Configuring Siebel eBusiness Applications > Working with the Entity Relationship Designer >
Associating Entity Attributes to Business Component Fields
After binding entities to business components, you can associate entity attributes to business component fields.
This task is a step in Process of Creating and Binding Entity Relationship Diagrams.
To bind entity attributes to Siebel business component fields
  1. Navigate to an entity relationship diagram.
    For instructions, see Navigating to Entity Relationship Diagrams.
  2. In the ERD canvas, select an entity.
  3. In the Entity Attribute list, select the attribute that you want to bind to a business component field.
  4. In the Business Component field, click the drop-down arrow, and then select a field.
    The entity attribute record is associated with the business component field.
