Configuring Siebel eBusiness Applications > Creating and Administering Lists of Values >
Identifying Which Columns to Enable
Not every list of values type can be enabled as multilingual. You need to determine which columns you can enable based on the LOV type. LOV types must meet the following conditions:
NOTE:  Do not set up a column for a MLOV unless you are sure that you intend to use that column for your implementation.
