Configuring Siebel eBusiness Applications > Creating and Administering Lists of Values > Reviewing List of Columns That Cannot be MLOV EnabledThere are special cases that should be considered when determining whether an LOV TYPE can be enabled for multilingual display. The columns listed in Table 55 cannot be MLOV enabled. This task is part of the Process of Enabling MLOVs. |
Configuring Siebel eBusiness Applications |
