Configuring Siebel eBusiness Applications > Configuring Multi-Value Group and Association Applets > Understanding How MVGs are ImplementedThis section summarizes how MVGs are implemented. It covers the following topics:
Multi-value group applets are implemented using object types illustrated in Figure 86. Figure 87 shows the object definitions used in the implementation of a multi-value group applet in greater detail, and identifies their interrelationships. The roles of the object definitions in Figure 87 are summarized in the following list and discussed in greater detail in the subsequent sections. The multi-value group example refers to the Account Address MVG applet illustrated in Figure 85. Each of the following objects is discussed in greater detail in the following sections.
Configuring Siebel eBusiness Applications |
