Configuring Siebel eBusiness Applications > Online Help Development > Customer Applications > Adding Help ContentYou can add help content in the existing HTML files, as explained in Customizing Help Content, or you can add new HTML files to complement the existing content. If you add new HTML files, you must add links to these new files from the existing files to make sure that your users will be able to access the content. To add help content by adding HTML files
Configuring Siebel eBusiness Applications |
