Configuring Siebel eBusiness Applications > Overview of Configuring Siebel Applications > About the Siebel Object Architecture > Physical User Interface LayerThe physical user interface layer consists of physical files, such as templates, Siebel tags, style sheets, and other file-based metadata, that control the layout and the look and feel of the user interface. The physical user interface layer separates style and layout definitions from user interface objects in the repository. This allows you to propagate style and layout definitions across multiple user interface objects. Table 3 lists physical user interface files. For more detailed information about templates, tags, or cascading style sheets, see Siebel Developer's Reference. |
Configuring Siebel eBusiness Applications |
