Configuring Siebel eBusiness Applications > Overview of Configuring Siebel Applications > About the Siebel Object Architecture > Summary of Object Types and RelationshipsObjects in each layer are built on objects in the layers below. For example, applets are based on business components, views are based on business objects, fields are based on columns. Figure 2 shows the relationships among some of the major object types in a Siebel application.
s
Configuring Siebel eBusiness Applications |
