Configuring Siebel eBusiness Applications > Configuring Picklists and Pick Applets > About Static Picklists >
Creating a Static Picklist Using the Pick List Wizard
You can create a static picklist by using the Pick List Wizard. To create a static pick list using the Pick List wizard
- From the Tools main menu, choose File > New Object.
The New Object Wizards dialog box appears.
NOTE: You can also invoke the Pick List wizard by selecting the field for which you would like to create a picklist, right-clicking, and choosing Add Pick List.
- Select the Pick List icon, and click OK.
- In the Pick List dialog box, enter the following information, and then click Next.
- Project
- Business Component (originating business component; the parent business component of the field that will display the picklist)
- Field
- In the Pick List Type dialog box, select Static, and then click Next.
NOTE: Static picklists draw their values from a predefined list of values (LOV). Dynamic picklists draw their values from a business component. For more information about dynamic picklists, see Creating Dynamic Picklist Objects.
- In the Pick List Definition dialog box, do one of the following:
- If you are creating a New List of Values, do the following:
- Enter a unique name for the picklist.
- Select the Create New List of Values option button, and then click Next.
- In the List of Values dialog box, enter a name for the List of Values and the Values.
For more information about List of Values, see Applications Administration Guide.
- Click Next.
- If you are using an existing List of Values, do the following:
- Select the Use predetermined List of Values radio button.
- Select the List of Values Type, and then click Next.
- In the third Pick List Definition dialog box, enter a search specification, a comment, and select whether you want the picklist to be bounded.
- Click Next.
- In the Finish dialog box, review the specifications for the picklist, and then click Finish.
