Configuring Siebel eBusiness Applications > Configuring Screens and Views > Process for Creating Screen Home Page Views >
Creating a New Screen Home Page View
After all the underlying objects are created (business components, business objects, and applets), you can create a screen home page view to display the objects and data in the user interface. This task is a step in Process for Creating Screen Home Page Views. To create a new screen home page view
- Choose File > New Object > View.
- Use the following information to complete the New View Wizard:
Project |
Choose ScreenHomePage. |
Name |
Follow the naming convention of Target Business Component Screen Homepage View. For example, Account Screen Homepage View. |
Title |
Follow the naming convention of Target Business Component Home. For example, Account Home |
Business Object |
Name of home page business object. For example, Account. See Creating a New Business Object for the Screen Home Page View. |
View Web Template |
Choose View 25 50 25; this View Web template will provide a three column layout. |
Applets |
Select the applets you want to appear on the screen home page view. Typically, these include the following:
- In the View Web Layout editor, verify the layout of the screen home page view.
The applet locations on screen home page views are described in the table below:
Rapid Search |
Left top |
Rapid Add |
Left bottom |
Homepage Banner |
Center To |
Public and Private View Link |
Center bottom |
Edit Layout |
Right top button |
Screen Home Task Assistant List Applet |
Right top |
Recent Record |
Right bottom |
- Navigate to the View Web Template Items for the view, and verify that the Applet Mode property is set correctly for each applet and verify the following Item Id properties for applet locations:
Rapid Search |
Query |
102 |
Rapid Add |
Edit |
103 |
Homepage Banner |
Base |
202 |
Base |
203 |
Edit Layout |
Base |
901 |
Base |
302 |
Recent Record |
Base |
303 |
For detailed information about creating views, see Process of Creating Views.
