Configuring Siebel eBusiness Applications > Configuring Screens and Views > Process for Creating Screen Home Page Views >
Adding a New Screen View to the Screen Object
For the new screen home page view to appear in the application, you must create a new Screen View object to represent it.
This task is a step in Process for Creating Screen Home Page Views.
To create a screen view object to represent the screen home page view
  1. Navigate to the Screen to which you are adding the home page view.
  2. Define a new Screen View object using the following information:
    Property
    Value
    Example
    Name
    Name of screen view
    Accounts Screen Homepage View
    Type
    Aggregate View
    View
    Name of view
    Viewbar Text
    Text to appear viewbar
    Accounts Home
  3. Define the Screen View sequence by right-clicking in the Object List Editor and then choosing edit Screen View Sequence.
    For detailed information about screen views, see About Screen Views.
