Configuring Siebel eBusiness Applications > Configuring Special Purpose Applets > Understanding How Chart Applets Are Constructed > Making X-Axis Labels VerticalYou can make x-axis labels vertical so that they do not overlap with each other. To do this, set the Vertical property to TRUE for the Chart Element object whose Axis Id property is set to XAxis. |
Configuring Siebel eBusiness Applications |
