Configuring Siebel eBusiness Applications > Configuring Spell Check >
Defining Spell Check Button User Properties
To set the Spell Check button User Properties
  1. In the Object Explorer, double-click the Controls object type to expand it.
  2. Select the Control User Properties object type.
  3. Click Control User Properties.
  4. In the Control User Properties window, create new records for the following user properties, with the corresponding values:
    Field
    Value
    Mode
    Edit
    Popup
    Spell Checker Popup Applet
    Popup Dimensions
    560 X 350 (recommended initial size)
