Siebel Financial Services Connector for ACORD P&C and Surety Guide > Troubleshooting > Integration Object Setup Problems > Errors in some component fieldsProblemFINS ACORD XML Transaction Manager returns an error message indicating that an error occurs in some component fields. SolutionMake inactive all unused integration component fields for internal integration objects created by the FINS ACORD Wizard. In some cases, two or more integration component fields are based on the same table column, which causes an SQL error in the object manager. |
Siebel Financial Services Connector for ACORD P&C and Surety Guide |
