Siebel Financial Services Connector for ACORD P&C and Surety Guide > Troubleshooting > Integration Object Setup Problems > Some required fields are empty in an XML stringProblemSome required fields are empty in an XML string generated by the FINS ACORD XML Converter. SolutionInitialize all required fields in the integration component "XML Literal Value" column. Some values are specified in the integration object/component/component field user property. Be sure to customize them to suit your integration needs. |
Siebel Financial Services Connector for ACORD P&C and Surety Guide |
