Siebel Financial Services Connector for ACORD P&C and Surety Guide > Configuration Roadmap > Creating Integration Objects in Siebel Tools >
Compiling the Integration Objects
After you create the integration objects, you compile them into the repository file for use by the connector. To compile the integration objects
- From Siebel Tools, choose Tools>Compile Projects.
The Object Compiler dialog box appears.
- Choose the project, browse to the repository file for the project, or create a new one, and then click Compile.
