Siebel Financial Services Connector for ACORD P&C and Surety Guide > Configuration Roadmap >
Creating Integration Objects in Siebel Tools
Integration objects define the intermediate format of the data so that it can be used by the connector components to translate between Siebel data formats and ACORD XML data formats.
You use the FINS ACORD Wizard to create the envelope, internal, and external integration objects, as well as the dispatcher map.
Table 23 shows the pre-setup user properties for the FINS ACORD Wizard.
Table 23. FINS ACORD Wizard User Properties
Name
Value
Comments
DispatcherMapName
ACORDDispMap
The Dispatcher Map Name. The wizard will use this map to update the key and value.
HasUIControl
Y
Internal use.
Integration Object Wizard
Y
Internal use.
Integration Object Base Object Type
Siebel Business Object
Internal use.
Operation KeyWord Match:0
Add/SAUpsert
Internal use. This means that when the wizard generates an external integration object for an Add message, it defines the operation in the transaction manager as SAUpsert. The operation name will be recorded in the dispatcher map.
Operation KeyWord Match:1
Inq/SAQuery
Internal use. This means that when the wizard generates an external integration object for an Inq message, it defines the operation in the transaction manager as SAUpsert. The operation name will be recorded in the dispatcher map.
Default Envelope Tag
ACORD
Value for Envelope Tag.
NOTE:  You can define a new Operation KeyWord Match:X if you need to. For example, if the ACORD DTD in the future supports the delete operation, you can define Operation KeyWord Match:2 as Delete/SADelete.
