Deployment Planning Guide > Application-Level Deployment Planning >
Siebel Email Response Performance Factors
The key factors that influence performance for Siebel Email Response deployments are as follows:
  • Inbound email messages processed per hour. This is the number of inbound email messages processed per hour (or some other time period) by your communications infrastructure.
    Requirements for processing outbound messages are relatively minor and are tied to inbound message volume. However, you must also consider other usage of the CommOutboundMgr component or of the email system. For example, you may configure the Send Email command to send email through CommOutboundMgr.
  • Volume of customer data. This is the total volume of customer data, including templates or categories, literature items, and so on. Template format (HTML or plain text) is a related factor.
    If you are deploying Siebel Smart Answer, you must also consider the size of the knowledge base.
Other factors include the size and complexity of inbound email messages and outbound replies.
Also relevant are user settings in the Outbound Communications section of the User Preferences screen, such as whether a reply contains the original message (Include Original Message in Reply setting), or whether HTML or plain text is an agent's default message format (Default Message Format setting).
Siebel Email Response coverage in this topic focuses on inbound and outbound email processing. In a multichannel environment, or when Siebel Universal Queuing is deployed, session communications performance issues also apply. Using Siebel Smart Answer, especially for auto-response capabilities, reduces the number of agents needed to handle incoming email and reduces corresponding demand on session-related computing resources, such as AOM or CommSessionMgr.
