Deployment Planning Guide > Siebel Client Deployment Planning > Standard Interactivity Application Deployment PlanningStandard interactivity applications do not allow users to select which columns to display in a view. They also do not support data-only user requests. All user requests require that the Siebel Server load page templates and rebuild each page for display. For an overview of standard interactivity mode, see About Standard and High Interactivity Modes. To maximize system performance, set the number of columns of data displayed in each view to the minimum needed. Also, when creating or modifying Web page templates, keep template designs as simple as possible. Standard interactivity applications can be run on several types of Web browsers. Test browser performance for all the types of Siebel clients you will deploy. Investigate all browser settings that affect page display, cookie management, or page caching. To reduce deployment administration costs, standardize on a browser for all users. Be sure to use the same browser type for development, testing, and production environments. For a list of browsers that support standard interactivity, see Siebel System Requirements and Supported Platforms. |
Deployment Planning Guide |
