Deployment Planning Guide > High-Availability Deployment Planning >
Recommended High Availability Techniques for Specific Services
The three high availability techniques that Siebel Systems supports are server clustering, load balancing, and resilient processing. Table 9 lists the recommended high availability technique for specific Siebel Enterprise deployment services:
  • Preferred. Indicates that more than one high availability technique is supported for this function, but this is the preferred technique and is the one you should use wherever possible.
  • Supported. Indicates a high availability technique is supported for this function. You can use this technique if local conditions prevent using the preferred technique.
  • Blank. The high availability techniques in the table are not available for this component.
Table 9. High-Availability Support Matrix for Siebel Components
Component
Clustering
Load Balancing
Resilient Processing
Gateway Name Server database (siebns.dat)
Preferred
Application Object Managers
Supported
Preferred
Communications Manager
Supported
Preferred
Dynamic Assignment
Preferred
Siebel Configurator
Supported
Preferred. Uses its own load balancing method
Document Server
Supported1
Preferred
Pricer
Supported
Preferred
EAI (adapters and connectors)
Supported
Preferred, whenever possible2
Supported
EAI Object Manager
Supported
Preferred
Field Service
Supported
Preferred
File System Manager
Supported
Preferred
Interactive Assignment
Supported
Preferred
MQ Series Receiver
Preferred
Replication Agent
Preferred
SAP BAPI Integration
Preferred
SAP IDOC Receiver
Preferred
SAP IDOC Receiver for MQ
Preferred
Server Request Broker
Supported
Preferred
Server Request Processor
Supported
Preferred
Siebel File System
Supported
Siebel Marketing
Supported
Preferred
Siebel Remote
Preferred
Workflow Monitor
Preferred
Workflow Process Manager
Supported
Preferred
1 Supported as long as Microsoft Office has been installed on all clustered nodes. This is particularly helpful in smaller deployments.
2 There are so many different types of EAI deployments that providing a single, standardized recommendation is not practical. For information about the best approach for your deployment, consult Siebel Expert Services.
