Developing and Deploying Siebel eBusiness Applications > Getting Started with Siebel Tools > Other Key Tasks for Managing Object Definitions > Viewing Project Differences Before Check InBefore checking in changes, you can view the differences between projects on your local repository and the projects on the server repository. This is useful for finding errors or omissions before committing your changes to the server. |
Developing and Deploying Siebel eBusiness Applications |
