Developing and Deploying Siebel eBusiness Applications > Getting Started with Siebel Tools > Other Key Tasks for Managing Object Definitions > Locking Projects in Your Local RepositoryWhen you are prototyping ideas or are making changes to object definitions that you plan to discard, it is good practice to lock the project locally rather than checking it out from the server. This way the project remains unlocked on the server, allowing other developers to check out the project from the server, while still allowing you to modify and test changes in your local repository.
NOTE: Do not lock a project locally on the server repository. |
Developing and Deploying Siebel eBusiness Applications |
