Developing and Deploying Siebel eBusiness Applications > Getting Started in the User Interface Layer >
Creating an NREC Project
Before configuring object definitions, you should create a new project for NREC. You use this project to group the new and modified object definitions. This makes it easier for you to find your work and makes it easy to export and import the object definitions.
To create a new project
  1. In the Object Explorer, select the Project object type.
    The Projects window opens in the Object List Editor.
  2. In the Projects window, right-click and choose New Record.
  3. Enter a new record with the following properties.
    Property
    Value
    Name
    NREC Configuration
    Locked
    TRUE
    The project is now available for you to use. Moving the objects that you create or modify helps you keep track of your configuration changes.
