Developing and Deploying Siebel eBusiness Applications > Getting Started in the User Interface Layer >
Setting Your Target Browser
Use the Target Browser feature of Siebel Tools to configure applications conditionally for different browsers, for example, Internet Explorer 5, Netscape 4.7, Netscape 6. Although you do not configure for different browsers in this guide, Siebel Tools requires that you have a target browser set. Otherwise, you can not open the Web Layout Editor.
To set a target browser
  1. Choose View > Toolbars > Configuration Context.
    The Configuration Context toolbar appears.
  2. From the drop-down list in the Target Browser field, choose Target Browser Config.
    The Target Browser Configuration dialog box appears.
  3. From the list of available browsers, select the target browsers and move them to the Selected pane—for example, select IE 5.0.
