ODBC Data Source Name |
Enter the ODBC data source name. |
Database User Name |
Enter the source database user name and source database password. |
Database Table Owner |
Enter the source database table owner and source table owner password. |
Source Database Repository Name |
Enter the database repository name and the target database repository name. |
Target RDBMS Platform |
Select the target RDBMS platform. IBM DB2 UDB v7.1 is the default. |
Target Database Encoding |
Select whether the target database is Unicode. |
Target Database ODBC Datasource |
Enter the target database ODBC datasource. |
Target Database User Name |
Enter the target database user name and password. |
Target Database Table Owner |
Enter the target database table owner and table owner password. |
Index Table Space Name (DB2-specific) |
Applicable only if you indicated that the target database is IBM DB2. Enter the index table space name and 4-KB Table Space Name. |
16-KB Table Space Name (DB2-specific) |
Applicable only if you indicated that the target database is IBM DB2. Enter the 16-KB table space name and 32-KB table space name. |
Index Table Space Name (Oracle-specific) |
Applicable only if you indicated that the target database is Oracle. There are two questions about index and table space. There are no 4-KB, 16-KB, and 32-KB table spaces in Oracle. For Microsoft SQL server, there are no screens about table spaces. |
Configuration Parameter Review |
Summary screen gives a list of your choices. You can accept this configuration by clicking finish. |
