This chapter tells you how to migrate your configuration from the development environment to the test environment. The data to be migrated includes:
Repository data and database schema changes are migrated using the Repository Migration Configuration Utility. Web templates and cascading style sheets are migrated by manually copying the files from the development server to the test server. Nonrepository data is migrated using the Application Deployment Manager. |
Developing and Deploying Siebel eBusiness Applications |
