Developing and Deploying Siebel eBusiness Applications > Testing the NREC Deployment > Benefits of Load Test Automation > Setting Up Your Load Testing EnvironmentTo set up your environment for automated load testing using Siebel Test Automation, perform the following steps.
NOTE: The Correlation Library is licensed for use only by licensed users of Siebel Test Automation. If you have not purchased a license for Siebel Test Automation, you are not permitted to write to or otherwise access the Correlation Library. In addition, set up your test tool so that it communicates properly with the Correlation Library. For more information, refer to the documentation from your test tool vendor. |
Developing and Deploying Siebel eBusiness Applications |
