Developing and Deploying Siebel eBusiness Applications > Migrating to the Test Environment > Migrating Nonrepository Data from Development to TestMigrating application run-time customization data from one Siebel application environment to another is a common requirement when going live to a new development, test, or production environment. The Application Deployment Manager (ADM) feature automates the migration of the Siebel application run-time customization data. Application Deployment Manager (ADM) is a feature that automates the process of migrating enterprise customization data (views, responsibilities, assignment rules, and so on) from one Siebel application environment to another. For example, ADM can move customization data from a development environment to a testing environment. ADM eliminates the former process of transferring this data manually. NOTE: The term migrating is used in the ADM context as the moving of data from one environment to another. No changes to the data take place during migration. The bulk of the administrative tasks to migrate data using ADM are performed at the Application Deployment Manager screen in the Siebel application GUI. These tasks are intended for those with Siebel administrator responsibility. The ADM set-up process in the ADM GUI creates a template in which one data type can be migrated on a regular basis, if required. The fundamental structure of this template is the deployment project. The deployment project consists of one or more data types that can be migrated. The following data types are available for migration with ADM:
These data types are preconfigured in the standard Siebel eBusiness application. Using Siebel Tools you can add more data types for use with ADM. For more information on migrating nonrepository data and using ADM, read Going Live with Siebel eBusiness Applications. |
Developing and Deploying Siebel eBusiness Applications |
