Developing and Deploying Siebel eBusiness Applications >
Setting Up a Developer's Local Database
After you have installed software as described in Installing Siebel Applications but before developers can do any configuration work, each developer must be set up with a local database. The process for setting up a local database includes tasks typically performed by an administrator and tasks performed by each developer. For example, an administrator creates database users and runs Siebel Remote server tasks to generate local databases, then each developer initializes their local database by downloading repository data from the server. For a list of tasks and where in the application they are performed, see Table 8.
NOTE:  This chapter gives you an overview of the sequence of tasks that need to be performed to set up a developer's local database. It is not necessary to complete these tasks to be able to follow the configuration examples in Getting Started in the User Interface Layer through Modifying the Look and Feel of the Web Client. In those chapters you can log in to the SAMPLE database using the SADMIN/SADMIN user name and password.
Table 8.  Tasks for Setting Up a Developer's Local Database
Task
Where Performed
Setting Up Database Users
RDBMS Software
Creating Positions
Administration - User screen
Associating Responsibilities
Setting Up Developers as Siebel Employees
Setting Up Developers as Mobile Web Clients
Administration - Siebel Remote screen
Generating a New Database Template
Administration - Server Configuration screen
Extracting the Local Database
Initializing Each Developer's Local Database
Siebel Tools
Performing a Full Get
Siebel Tools
