Developing and Deploying Siebel eBusiness Applications > Creating a Virtual Business Component > Exposing the Fields in the User Interface >
Creating a New View
To display the Renovations list applet you need to add it to a view. NREC requires a standard master-detail view, showing the House Form applet on top and the Renovations list applet on the bottom. This displays the renovation records for each house record. To create a new view
- Choose File > New Object.
- In the New Objects Wizard dialog box, select View.
The New View Wizard opens.
- Complete the wizard using the values as shown in the following table.
Project |
NREC Configuration |
Name |
House Details - Renovations View |
Title |
Renovations |
Business Object |
Internal Product |
Web Template |
View Detail (Parent with Pointer) |
Applets |
Product Form Applet Renovations List Applet |
