Overview: Siebel Enterprise Application Integration > Understanding Integration Paradigms > About the Options for Your IntegrationThere are several ways you can approach your integration, depending on your needs. You can connect Siebel applications and your back office system or eCommerce applications using prebuilt Siebel EAI connectors. You can connect Siebel applications and an external application using Siebel EAI custom-built connectors. You can integrate Siebel applications with middleware solutions. Or you can integrate Siebel applications with external applications using a third-party EAI product. Siebel Business Applications provide solutions for each element of the EAI planning process.
Overview: Siebel Enterprise Application Integration |
