Overview: Siebel Enterprise Application Integration > Understanding Integration Paradigms > About Usage Models >
Using the Batch Model in Your Integration
Batch processing typically is used for periodic uploads or downloads of large amounts of information into the Siebel Database. Typical batch scenarios involving Siebel applications include:
- Uploading a batch of product catalog and item information into a Siebel application from an external system.
- Downloading a batch of opportunities from Siebel applications to another database.
