Overview: Siebel Enterprise Application Integration > Custom Business Scenarios > About Data Access and Replication >
Providing Access to a Company Catalog
In this scenario, you need to provide your salespeople access to a product catalog while they are on the road. So, you need to import the catalog information into Siebel applications so that Siebel Remote can take care of the mobile replication. Siebel Enterprise Integration Manager (EIM) imports this information. Table 5 details the requirement for importing a company's catalog for mobile replication.
Table 5. Company Catalog Replication Integration Requirement
Technological Requirement |
To import the company's product catalog |
High-volume batch replications |
Siebel Enterprise Integration Manager (EIM) |
