Integration Platform Technologies: Siebel Enterprise Application Integration > Creating and Maintaining Integration Objects > About the Integration Object BuilderThe Integration Object Builder builds a list of valid components from which you can choose the components to include in your Siebel integration object. NOTE: The Integration Object Builder provides a partial rendering of your data in the integration object format. You must review the integration object definition and complete the definition of your requirements. In particular, confirm that the user key definitions are defined properly. You may need to enter keys and user properties manually or inactivate unused keys and fields in Siebel Tools. Do not expect to use the integration object without modification. The following checklist gives the high-level procedure for creating an integration object:
Integration Platform Technologies: Siebel Enterprise Application Integration | Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
