Integration Platform Technologies: Siebel Enterprise Application Integration > Integration Objects >
Integration Objects Terminology
This chapter describes the concepts that are often referred to when using inconsistent terminology on different systems. Table 4 has been included to clarify the information in this chapter by providing a standard terminology for these concepts.
Table 4. Integration Objects Terminology
Data that describes data. For example, the term data type describes data elements such as char, int, Boolean, time, date, and float.
Siebel business object
A Siebel object type that creates a logical business model using links to tie together a set of interrelated business components. The links provide the one-to-many relationships that govern how the business components interrelate in this business object.
A constituent part of any generic object.
Siebel business component
A Siebel object type that defines a logical representation of columns in one or more database tables. A business component collects columns from the business component's base table, its extension tables, and its joined tables into a single structure. Business components provide a layer of abstraction over tables. Applets in Siebel Business Applications reference business components; they do not directly reference the underlying tables.
A generic reference to a data structure that can contain one data element.
Siebel integration component field
A data structure that can contain one data element in a Siebel integration component.
A constituent part of a Siebel integration object.
Integration object
An integration object of any type, including the Siebel integration object, the SAP BAPI integration object, and the SAP IDOC integration objects.
Integration object instance
Actual data, usually the result of a query or other operation, which is passed from one business service to another, that is structurally modeled on a Siebel integration object.
An object stored in the Siebel repository that represents a Siebel business object.
Integration message
A bundle of data consisting of two major parts:
  • Header information that describes what should be done with or to the message itself
  • Instances of integration objects; that is, data in the structure of the integration object
Integration Platform Technologies: Siebel Enterprise Application Integration Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices.
