Integration Platform Technologies: Siebel Enterprise Application Integration > EAI Siebel Adapter > EAI Siebel Adapter Methods >
Synchronize Method
You can use the Synchronize method to make the values in a business object instance match those of an integration object instance. This operation can result in updates, insertions, or deletions in the business components. The following rules apply to the results of this method:
  • If a child component is not present in the integration object instance, the corresponding child business component rows are left untouched.
  • If the integration object instance's child component has an empty container, then all child records in the corresponding business component are deleted.
  • For a particular child component, records that exist in both the integration object instance and business component are updated. Records that exist in the integration object hierarchy and not in the business component are inserted. Records in the business component and not in the integration object instance are deleted.
NOTE:  The Synchronize method updates only the fields specified in the integration component instance.
Example of Synchronize Method on Deleted Unmatched Children
This first example demonstrates deleting unmatched children when using the Synchronize method. This example uses data present in the sample database.
  <?xml version = "1.0" encoding = "UTF-8"?><?Siebel-Property-Set EscapeNames="false"?>
  <SiebelMessage MessageId = "1-2QY5" IntObjectName = "EAI Account" MessageType =
  "Integration Object" IntObjectFormat = "Siebel Hierarchical">
<ListOfAccount>
<Account>
<AccountStatus>Active</AccountStatus>
<CSN>1-3JGO7</CSN>
<CurrencyCode>USD</CurrencyCode>
<LanguageCode>ENU</LanguageCode>
<Location>Test</Location>
<Name>ABC Corp</Name>
<ListOfAccount_BusinessAddress>
<Account_BusinessAddress IsPrimaryMVG = "Y">
<AddressActiveStatus>Y</AddressActiveStatus>
<BillAddressFlag>Y</BillAddressFlag>
<City>ATown</City>
<Country>USA</Country>
<MainAddressFlag>Y</MainAddressFlag>
<ShipAddressFlag>Y</ShipAddressFlag>
<StreetAddress>123 Main St</StreetAddress>
</Account_BusinessAddress>
<Account_BusinessAddress IsPrimaryMVG = "N">
<City>BTown</City>
<StreetAddress>456 Second Street</StreetAddress>
</ListOfAccount_BusinessAddress>
<ListOfContact>
<Contact>
<ActiveStatus>Y</ActiveStatus>
<FirstName>User1</FirstName>
<LastName>User1</LastName>
<Organization>Default Organization</Organization>
<ListOfContact_Organization>
<Contact_Organization IsPrimaryMVG = "Y">
<OrganizationIntegrationId/>
</Contact_Organization>
</ListOfContact_Organization>
<ListOfContact_AlternatePhone/>
</Contact>
<Contact>
<FirstName>User2</FirstName>
<LastName>User2</LastName>
</Contact>
</ListOfContact>
<ListOfAccount_Organization>
<Account_Organization IsPrimaryMVG = "Y">
<OrganizationId>0-R9NH</OrganizationId>
</Account_Organization>
</ListOfAccount_Organization>
</Account>
</ListOfAccount>
  </SiebelMessage>
Then the following XML (integration object instance) is submitted with Synchronize:
<ListOfAccount>
<Account>
<CSN>1-3JGO7</CSN>
<Competitor>Y</Competitor>
<LanguageCode>CHS</LanguageCode>
<Location>test</Location>
<ListOfContact>
<Contact>
<ActiveStatus>N</ActiveStatus>
<MiddleName></MiddleName>
</Contact>
<Contact>
<FirstName>User3</FirstName>
<LastName>User3</LastName>
</Contact>
</ListOfContact>
</Account>
</ListOfAccount>
  </SiebelMessage>
Following is the result you will receive. Because the contact information is included in the integration object instance, User2 in the database is deleted because it was an unmatched node. User1 is updated because it is a matched node. User3 is inserted because it is a new node. Since Business Address was not included in the integration object instance, it is left in the business object.
<ListOfAccount>
<Account>
<CSN>1-3JGO7</CSN>
<City>ATown</City>
<City>BTown</City>
<ListOfContact>
<Contact>
</Contact>
<Contact>
</Contact>
</ListOfContact>
</Account>
</ListOfAccount>
  </SiebelMessage>
Table 12 is a high-level representation of the previous example.
Table 12. Representation of the Synchronize Method on Deleted Unmatched Children
Record In Database
Integration Object Instance
Record After Synchronize
Account: ABC Corp
BusinessAdress: 123 Main St.
BusinessAdress: 456 Second St.
Contact: User1
Organization: Default Org.
Contact: User2
Account: ABC Corp
Contact: User1
Contact: User3
Account: ABC Corp
Contact: User1
Contact: User3
This second example demonstrates how all records with an empty container are deleted when using the Synchronize method.
If you start with this business component data:
<ListOfAccount>
<Account>
<CSN>1-3JGO7</CSN>
<AddressId>1-3JGOA</AddressId>
<City>MyTown</City>
<Country>Canada</Country>
<AddressId>1-3JGOB</AddressId>
<City>YourTown</City>
<ListOfContact>
<Contact>
<MiddleName/>
</Contact>
<Contact>
<MiddleName/>
</Contact>
</ListOfContact>
</Account>
</ListOfAccount>
  </SiebelMessage>
And the following integration object instance is passed in:
<ListOfAccount>
<Account>
<CSN>1-3JGO7</CSN>
<ListOfContact/>
</Account>
</ListOfAccount>
  </SiebelMessage>
After the sync operation, all the children contacts are deleted because none of the nodes match.
<ListOfAccount>
<Account>
<CSN>1-3JGO7</CSN>
<City>MyTown</City>
</Account>
</ListOfAccount>
  </SiebelMessage>
Table 13 is a high-level representation of the operation.
Table 13. Representation of Records with Empty Containers Being Deleted Using Synchronize Method
Record In Database
Account: ABC Corp
Contact: User1
Contact: User2
Account: ABC Corp
Contact:
Account: ABC Corp
Integration Platform Technologies: Siebel Enterprise Application Integration Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices.
