Integration Platform Technologies: Siebel Enterprise Application Integration > Siebel Virtual Business Components >
Custom Business Service Example
The following is an example of the Siebel eScript implementation of a business service for a VBC. The fields configured for this simple VBC are AccountId, Name, Phone, Location, and AccessId. AccessId is the primary key in the external data source. AccessId is included in the VBC fields to make updating and deleting the fields simple and is configured as a hidden field: function Service_PreInvokeMethod (MethodName, Inputs, Outputs)
if (MethodName == "Init") {
return(Init(Inputs, Outputs));
else if (MethodName == "Query") {
return(Query(Inputs, Outputs));
else if (MethodName == "PreInsert") {
return(PreInsert(Inputs, Outputs));
else if (MethodName == "Insert") {
return(Insert(Inputs, Outputs));
else if (MethodName == "Update") {
return(Update(Inputs, Outputs));
else if (MethodName == "Delete") {
return(Delete(Inputs, Outputs));
else {
return (ContinueOperation);
function Init (Inputs, Outputs)
// For debugging purpose...
logPropSet(Inputs, "InitInputs.xml");
Outputs.SetProperty("AccountId", "");
Outputs.SetProperty("Name", "");
Outputs.SetProperty("Phone", "");
Outputs.SetProperty("AccessId", "");
Outputs.SetProperty("Location", "");
logPropSet(Outputs, "InitOutputs.xml");
return (CancelOperation);
function Query(Inputs, Outputs)
logPropSet(Inputs, "QueryInputs.xml");
var selectStmt = "select * from Contacts ";
var whereClause = "";
var orderbyClause = "";
// You have the following properties if you want to use them
// Inputs.GetProperty("Business Component Name")
// Inputs.GetProperty("Business Component Id")
// Inputs.GetProperty("Remote Source")
// If you configured Maximum Cursor Size at the buscomp,
// get max-rows property
var maxRows = Inputs.GetProperty("max-rows");
// get search-string
var searchString = Inputs.GetProperty("search-string");
if (searchString != "" )
// convert the search-string into a where clause
searchString = stringReplace(searchString, '*', '%');
searchString = stringReplace(searchString, '[', ' ');
searchString = stringReplace(searchString, ']', ' ');
searchString = stringReplace(searchString, '~', ' ');
searchString = stringReplace(searchString, '"', "'");
whereClause = " where ";
whereClause = whereClause + searchString;
// match, search-spec, sort-spec
var childCount = Inputs.GetChildCount();
var child, sortProp;
for (var i = 0; i < childCount; i++)
child = Inputs.GetChild(i);
if (child.GetType() == "")
// Use this child property set if you want to use the old match field list.
// We are not using this in this example. We'll use search-string instead.
else if (child.GetType() == "search-spec")
// Use this child property set if you want to use the hierarchical
// representation of the search-string.
else if (child.GetType() == "sort-spec")
// This child property set has the sort spec. We'll use this in this example
orderbyClause = " order by ";
var sortFieldCount = child.GetChildCount();
for (var j = 0; j < sortFieldCount; j++)
// compose the order by clause
sortProp = child.GetChild(j);
orderbyClause += sortProp.GetProperty("field");
var sortOrder = sortProp.GetValue();
if (sortOrder == "DESCENDING")
orderbyClause += " desc";
if (j < sortFieldCount-1)
orderbyClause += ", ";
// Now, our complete select statement is...
selectStmt += whereClause + orderbyClause;
// Now, query the data source
var conn = getConnection();
var rs = getRecordset();
rs.Open(selectStmt, conn);
// We're only going to return no more than maxRows of records.
var count = rs.RecordCount();
if (maxRows != "")
if (count > maxRows)
count = maxRows
// We'll go through the recordset and add them to the Outputs PropertySet.
var fcount, fields, row;
for (i = 0; i < count; i++)
row = TheApplication().NewPropertySet();
fields = rs.Fields();
fcount = fields.Count();
for (j = 0; j < fcount; j++)
var fieldValue = fields.Item(j).Value();
if (fieldValue == null)
row.SetProperty(fields.Item(j).Name(), "");
else
row.SetProperty(fields.Item(j).Name(), fieldValue);
Outputs.AddChild(row);
rs.MoveNext();
logPropSet(Outputs, "QueryOutputs.xml" );
// clean up
child = null;
sortProp = null;
row = null;
rs.Close();
rs = null;
conn.Close();
conn = null;
function PreInsert (Inputs, Outputs)
logPropSet(Inputs, "PreInsertInputs.xml");
var defaults = TheApplication().NewPropertySet();
defaults.SetProperty("Location", "KO");
Outputs.AddChild(defaults);
logPropSet(Outputs, "PreInsertOutputs.xml");
// clean up
defaults = null;
function Insert (Inputs, Outputs)
logPropSet(Inputs, "InsertInputs.xml");
var fieldList = "";
var valueList = "";
// Inputs should have only 1 child property set.
var child = Inputs.GetChild(0);
var fieldName = child.GetFirstProperty();
var fieldValue;
while (fieldName != "")
fieldValue = child.GetProperty(fieldName);
if (fieldValue != "")
if (fieldList != "")
fieldList += ", ";
valueList += ", ";
fieldList += fieldName;
valueList += "'" + fieldValue + "'";
fieldName = child.GetNextProperty();
// The insert statement is...
var insertStmt = "insert into Contacts (" + fieldList + ") values (" + valueList + ")";
// Now, inserting into the data source...
conn.Execute (insertStmt);
// In this example, we need to query back the record just inserted to get
// the value of its primary key. We made this primary key part of the buscomp
// to make update and delete easy. The primary key is "AccessId".
var selectStmt = "select * from Contacts where ";
if (fieldName != "AccessId")
if (whereClause != "")
whereClause += " and ";
if (fieldValue == "")
whereClause += fieldName + " is null";
else
whereClause += fieldName + "='" + fieldValue + "'";
// The select statement is...
selectStmt += whereClause;
// Now, let's select the new record back
// We're expecting only one row back in this example.
var fcount, fields, row, fieldValue;
for (var j = 0; j < fcount; j++)
else
logPropSet(Outputs, "InsertOutputs.xml");
// clean up
child = null;
row = null;
rs.Close();
rs = null;
conn.Close();
conn = null;
function Update (Inputs, Outputs)
logPropSet(Inputs, "UpdateInputs.xml");
var child;
var fieldName, fieldValue;
var updateStmt = "update Contacts set ";
var setClause = "";
var whereClause;
// Go through each child in Inputs and construct
// necessary sql statements for update and query
fieldName = child.GetProperty("Field Name");
fieldValue = child.GetProperty("Field Value");
// We only need to update changed fields.
if (child.GetProperty("Changed") == "true")
if (setClause != "")
setClause += ", ";
setClause += fieldName + "=null";
else
setClause += fieldName + "='" + fieldValue + "'";
if (fieldName == "AccessId")
whereClause = " where AccessId = " + fieldValue;
// The update statement is...
updateStmt += setClause + whereClause;
// Now, updating the data source...
conn.Execute (updateStmt);
// How to construct the Outputs PropertySet can vary, but in this example
// We'll query back the updated record from the data source.
var selectStmt = "select * from Contacts" + whereClause;
// Now, let's select the updated record back
// In this example, we're returning all the fields and not just
// the updated fields. You can only return those updated
// fields with the new value in the Outputs property set.
else
logPropSet(Outputs, "UpdateOutputs.xml");
// clean up
child = null;
row = null;
rs.Close();
rs = null;
conn.Close();
conn = null;
function Delete (Inputs, Outputs)
logPropSet(Inputs, "DeleteInputs.xml");
// In this example, we're only using the AccessId
// (it's the primary key in the Contacts db)
// for delete statement for simplicity.
var deleteStmt = "delete from Contacts where AccessId = " + child.GetProperty("AccessId");
// Now, let's delete the record from the data source.
conn.Execute(deleteStmt);
logPropSet(Outputs, "DeleteOutputs.xml");
// Returning empty Outputs property set.
// clean up
conn.Close();
conn = null;
The following functions are helper functions: function getConnection ()
// VBCContact is the ODBC data source name
var connectionString = "DSN=VBCContact";
var uid = "";
var passwd = "";
var conn = COMCreateObject("ADODB.Connection");
conn.Mode = 3;
conn.CursorLocation = 3;
conn.Open(connectionString , uid, passwd);
return conn;
function getRecordset()
var rs = COMCreateObject("ADODB.Recordset");
return rs;
function logPropSet(inputPS, fileName)
// Use EAI XML Write to File business service to write
// inputPS property set to fileName file in c:\temp directory.
var fileSvc = TheApplication().GetService("EAI XML Write to File");
var outPS = TheApplication().NewPropertySet();
var fileLoc = "c:\\temp\\" + fileName;
var tmpProp = inputPS.Copy();
tmpProp.SetProperty("FileName", fileLoc);
fileSvc.InvokeMethod("WritePropSet", tmpProp, outPS);
// clean up
outPS = null;
fileSvc = null;
tmpProp = null;
function stringReplace (string, from, to)
// Replaces from with to in string
var stringLength = string.length;
var fromLength = from.length;
if ((stringLength == 0) || (fromLength == 0))
return string;
var fromIndex = string.indexOf(from);
if (fromIndex < 0)
return string;
var newString = string.substring(0, fromIndex) + to;
if ((fromIndex + fromLength) < stringLength)
newString += stringReplace(string.substring(fromIndex+fromLength, stringLength), from, to);
return newString;
For more examples of VBCs, see Developing and Deploying Siebel Business Applications.
