Integration Platform Technologies: Siebel Enterprise Application Integration > Siebel Virtual Business Components > Custom Business Service Methods >
Business Services Methods and Their Property Sets
The following examples display each method's input and output property sets for a VBC Contact that displays simple contact information for a given account. These examples are based on the example in the Custom Business Service Example.
NOTE:  All the optional parameters have been omitted from these examples to simplify them.
Delete
The Delete method is called when a record is deleted. Figure 32 illustrates the property set for the Delete input.
Figure 32. Delete Input Property Set
The following is the XML representation of the property set shown in Figure 32:
<?xml version="1.0" encoding="UTF-8" ?>
<?Siebel-Property-Set EscapeNames="true"?>
<PropertySet
Business_spcComponent_spcId="1"
Business_spcComponent_spcName="Contact">
<PropertySet
AccountId="1-6"
Name="Max Adams"
Phone="(408)234-1029"
Location="San Jose"
AccessId="146" />
</PropertySet>
Figure 33 illustrates the property set for Delete output.
Figure 33. Delete Output Property Set
The following is the XML representation of the property set shown in Figure 33:
<PropertySet />
Error Return
Figure 34 illustrates the property set for the Error Return, when an error is detected.
Figure 34. Error Return Property Set
The following is the XML representation of the property set shown in Figure 34:
<PropertySet>
<Status Status="4"
Error_spcField="Name"
Error_spcText="Name must not be empty"/>
</PropertySet>
Init
The Init method is called when the VBC is first instantiated. It initializes the VBC. It expects to receive the list of fields supported by the external system.
NOTE:  When a field is not initialized in the Init method of the VBC, the Update method is not fired when the field gets updated.
Figure 35 illustrates the property set for Init input.
Figure 35. Init Input Property Set
The following is the XML representation of the property set shown in Figure 35:
<?xml version="1.0" encoding="UTF-8"?>
<PropertySet
Business_spcComponent_spcName="Contact"/>
Figure 36 illustrates the property set for Init output.
Figure 36. Init Output Property Set
The following is the XML representation of the property set shown in Figure 36:
<PropertySet
AccountId=""
Name=""
Phone=""
Location=""
AccessId="" />
Insert
The Insert method is called when a New Record is committed. Figure 37 illustrates the property set for Insert input.
Figure 37. Insert Input Property Set
The following is the XML representation of the property set shown in Figure 37:
<PropertySet
<PropertySet
AccountId="1-6"
Name="Max Adams"
Phone="(398)765-1290"
Location="Troy"
AccessId="" />
</PropertySet>
Figure 38 illustrates the property set for Insert output.
Figure 38. Insert Output Property Set
The following is the XML representation of the property set shown in Figure 38:
<PropertySet
<PropertySet
AccountId="1-6"
Name="Max Adams"
Location="Troy"
AccessId="146" />
</PropertySet>
PreInsert
The PreInsert method is called when a New Record operation is performed. It supplies default values. Figure 39 illustrates the property set for PreInsert input.
Figure 39. PreInsert Input Property Set
The following is the XML representation of the property set shown in Figure 39:
<PropertySet
Figure 40 illustrates the property set for PreInsert output.
Figure 40. PreInsert Output Property Set
The following is the XML representation of the property set shown in Figure 40:
<PropertySet>
<PropertySet Location="San Jose" />
</PropertySet>
Query
The Query method is called when a search is performed. The Query method must be supported by every VBC. Each record that matches the query is represented as a property set. For example, if 5 records match the query, there will be 5 child property sets. Each property set contains a list of field names—field value pairs representing the values of each field for that particular record. Figure 41 and Figure 42 illustrate the property set for Query input.
Figure 41. Query Input Property Set (Part 1)
Click for full size image
Figure 42. Query Input Property Set (Part 2)
The following is the XML representation of the property set shown in Figure 41 and Figure 42:
<PropertySet
max-rows="6"
search-string="([Phone] IS NOT NULL) AND ([AccountId] = "1-6")"
<PropertySet AccountId="1-6" />
<search-spec>
  <node node-type="Binary Operator">AND
  <node node-type="Unary Operator">IS NOT NULL
  <node node-type="Identifier">Phone</node>
    </node>
    <node node-type="Binary Operator">=
    <node node-type="Identifier">AccountId</node>
    <node value-type="TEXT" node-type="Constant">1-6</node>
    </node>
  </node>
</search-spec>
<sort-spec>
  <sort field="Location">ASCENDING</sort>
  <sort field="Name">DESCENDING</sort>
</sort-spec>
</PropertySet>
Figure 43 illustrates the property set for Query output.
Figure 43. Query Output Property Set
The following is the XML representation of the property set shown in Figure 43:
<PropertySet>
<PropertySet
AccountId="1-6"
Name="Sara Chen"
Phone="(415)298-7890"
Location="San Francisco"
AccessId="128" />
<PropertySet
AccountId="1-6"
Name="Eric Brown"
Phone="(650)123-1000"
Location="Palo Alto"
AccessId="129" />
</PropertySet>
Update
The Update method is called when a record is modified. Figure 44 illustrates the property set for Update input.
Figure 44. Update Input Property Set
The following is the XML representation of the property set shown in Figure 44:
<PropertySet
<PropertySet
Field_spcName="AccountId"
Changed="false"
Field_spcValue="1-6"/>
<PropertySet
Field_spcName="Name"
Changed="false"
Field_spcValue="MaxAdams"/>
<PropertySet
Field_spcName="Phone"
Changed="true"
Field_spcValue="(408)234-1029"/>
<PropertySet
Field_spcName="Location"
Changed="true"
Field_spcValue="SanJose"/>
<PropertySet
Field_spcName="AccessId"
Changed="false"
Field_spcValue="146" />
</PropertySet>
Figure 45 illustrates the property set for the Update output.
Figure 45. Update Output Property Set
The following is the XML representation of the property set shown in Figure 45:
<PropertySet
<PropertySet
Phone=="(408)234-1029"
</PropertySet>
Integration Platform Technologies: Siebel Enterprise Application Integration Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices.
