Integration Platform Technologies: Siebel Enterprise Application Integration > Web Services > About Siebel Authentication and Session Management SOAP Headers >
Combinations of Session Types and Authentication Types
Table 10 summarizes the combinations of authentication types and session types.
Table 10. Summary of Authentication Types and Session Types
Authentication Type
Session Type
Description
None
None
A single request is sent with an anonymous user login, and the session is closed after the response is sent out.
In order for the anonymous session to be identified by the SWSE plugin, UsernameToken and PasswordText need to be excluded in the SOAP headers.
Username and password
None
A single request is sent with the username and password used to log in, and the session is closed after the response is sent out.
Stateless
The initial request to log in establishes a session that is to remain open and available for subsequent requests. Username/password are used to log in and a session token is returned in a SOAP header included in the outbound response. The session remains open.
Session token (stateless)
Stateless
Request to reconnect to an established session, using the information contained in the session token. If the session has been closed, automatic relogin occurs. The Siebel servers include the session token in the SOAP header of the response. The session remains open.
None
When a SOAP header carries a session token and has the session type set to None, then the Session Manager on the SWSE closes (logs out) of this session, and invalidates the session token. The session token is not used after the session is invalidated.
For examples that illustrate some of these combinations, see Examples of Using SOAP Headers for Authentication and Session Management.
Integration Platform Technologies: Siebel Enterprise Application Integration Copyright © 2008, Oracle and/or its affiliates. All rights reserved. Legal Notices.
