Transports and Interfaces: Siebel Enterprise Application Integration > Using Siebel OLE DB Provider > Installing the Siebel OLE DB Provider > Configuring and Testing the Siebel OLE DB ProviderYou configure and test Siebel OLE DB Provider using the siebel.udl file that is installed in the [oledb] Table 19 presents the necessary connection properties. When you have entered these values, test the connection to the data source by clicking the Test Connection button on the Microsoft Data Link Properties dialog box. If the connection is valid, you receive a confirmation. If you receive a successful connection confirmation, you can use the same data source name with any OLE DB-enabled application to connect to the Siebel OLE DB Provider. About the Siebel OLE DB Provider in the Server Connected ModeIn the server connected mode Siebel OLE DB Provider uses the Siebel Web client to communicate with the rest of the Siebel environment. In this mode, the Data Source name defines the connect string that is used by the Siebel Web client to connect with the Siebel Gateway. A sample Excel query that uses Siebel OLE DB provider in Server mode follows: QueryType=OLEDB CommandType=Default NOTE: There should be no blank lines between commands such as QueryType, Version, and CommandText. Connection information should be in one continuous line. About the Siebel OLE DB Provider Local WIN32 Siebel Client ModeIn the local client mode, the Siebel Business Object Manager allows the Siebel OLE DB Provider to connect to the Siebel application residing on the same machine. In the local client mode, the Data Source name defines a path to the Siebel configuration file. Table 20 below defines the syntax. CAUTION: When you install using the Siebel EAI Connectors installation option, the Siebel OLE DB Provider can only be used in the Server Connected Mode. The Local Client Mode is not available. A sample Excel query that uses Siebel OLE DB Provider in the local client mode follows: QueryType=OLEDB |
Transports and Interfaces: Siebel Enterprise Application Integration |
