XML Reference: Siebel eBusiness Application Integration Volume V > Siebel XML Converters >
EAI XML Converter
The EAI XML Converter uses integration object definitions to determine the XML representation for data. It converts the data between an integration object hierarchy and an XML document. Figure 4 shows the translation of an XML document into an integration object property set in Siebel application and back again. The integration object property set of type Siebel Message will appear as a child of the Service Method Arguments property set.
Figure 4.  XML Document to Integration Object
Click for full size image
