XML Reference: Siebel eBusiness Application Integration Volume V > Siebel XML Converters >
Siebel XML Converter Business Services Comparison
Table 16 shows the basic differences between the four XML Converter business services. The table also gives guidelines on the appropriate usage.
Key
n   Supported by converter          o Supported in conjunction with second converter
Table 16.  Siebel XML Converters Comparisons
User Requirement
EAI
XML
Converter
XML Hierarchy Converter
EAI Integration Object to XML Hierarchy Converter1
XML Converter
Using Siebel Workflow
n
n
o
Using Siebel Data Mapper
n
o2
o
Using eScripts for data transformation in your integration
n
n
o
Using custom XML envelopes in your integration
n
o
Using Dispatch Service in your integration
n
o
Your XML represents Business Service arguments
o
n
Serializing Property Sets as XML
o
n
Internal Representation
Siebel Message (Integration Object Instance)
XML Hierarchy
Property
Set
Prerequisites
Create an Integration Object definition
n
n
1Must be used in conjunction with the XML Hierarchy Converter.
2Must be used in conjunction with the Integration Object Hierarchy Converter.
