Table 20. XML Document to Integration Object Hierarchy Method Input Arguments
XML Document |
<Value> |
String |
The input XML document. |
Integration Object Name |
IntObjectName |
String |
Name of the Integration Object to use in cases where the Siebel Message envelope might not be present. |
Integration Object Lookup Rule Set |
IntObjectNameLookupRuleSet |
String |
Rule Set for the EAI Dispatcher Service for finding out Integration Object Name in cases where the Siebel Message envelope might not be present. |
Validate External Entity |
ValidateExternalEntity |
String |
If True, the parser will be set to validate against external metadata, such as DTDs. |
External Entity Directory |
ExternalEntityDirectory |
String |
The directory to use for finding external entities referenced in the XML document, such as DTDs. |
Truncate Field Values |
TruncateFieldValues |
String |
Default is False. If True, truncate any fields longer than their maximum size, as specified in the Integration Component field definition. |
Ignore Character Set Conversion Errors |
IgnoreCharSetConvErrors |
String |
Default is False. If the Siebel application cannot represent a given character set—such as the local code page character set—conversion errors are logged, including a warning log entry. When set to True, only a warning message is logged. |
Contains Inline Attachments |
ContainsInlineAttachments |
String |
This is True if the file attachment content was included in the original XML document; otherwise it is False. From MIME (Multipurpose Internet Mail Extensions) Converter only. |
Tags on Separate Lines |
String |
Default is False. When True, a line feed is placed at the end of each tag. |
n/a |
ProcessElementsOnly |
String |
Default is False. If set to True, processing of attributes is skipped. You must manually create and name this input argument if it is required by your business needs. |
n/a |
GenerateProcessingInstructions |
String |
Default is True. If set to False the Siebel processing instructions are not written. You must manually create and name this input argument if it is required by your business needs. |
