XML Reference: Siebel eBusiness Application Integration Volume V > XML Representation of Property Sets >
Element and Attribute Naming
The property set Type (which maps to an XML element name) and the names of individual properties (which map to XML attribute names) do not necessarily follow the XML naming rules. For example, a name can include characters such as a space, a quote, a colon, a left parenthesis, or a right parenthesis that are not allowed in XML element or XML attribute names. As a result, you must perform some conversion to generate a valid XML document.
When creating an XML document from a property set hierarchy, the XML Converter will make sure that legal XML names are generated. There are two different approaches provided to handle name translation. The approach is determined by the EscapeNames user property on the XML Converter service. This user property can be either True or False.
  • True. If EscapeNames is True, instances of illegal characters are converted to an escape sequence that uses only legal characters. For example, a space is converted to the characters _spc. When an XML document is parsed to a property set hierarchy, the escape sequences are converted back to the original characters. For example, the name Account (SSE) becomes Account_spc_lprSSE_rpr.
    Table 5 shows the escape sequences that are used by the XML Converter.
    Table 5.  XML Converter Escape Sequences
    Character in Property Set
    Generated Escape Sequence
    Double Quote
    Single Quote
    Left Parenthesis
    Right Parenthesis
    Pound symbol
    (Forward) slash
    Question Mark
    Less Than
    Greater Than
    Other illegal characters not listed above
    _<Unicode character code>
  • False. If EscapeNames is False, the XML Converter removes illegal characters. These characters include the space ( ), double quote ("), single quote('), semicolon (;), left parenthesis ((), right parenthesis ()), and ampersand (&). For example, the XML Converter changes the name Account (SSE) to AccountSSE.
    NOTE:  These conversions are not reversible: the original names cannot be obtained from the XML names.
If a property set instance does not have a value for its Type member variable, the XML Converter uses the name PropertySet for the corresponding element's name.
