XML Reference: Siebel eBusiness Application Integration Volume V > XML Integration Scenarios > Scenario 2: Integration Using External XML and an XSD or DTD >
Running the Integration
In this scenario, assume that the external application has generated external XML and includes an associated XSD or a DTD. At runtime, the Siebel application:
- Calls the EAI XML Converter to convert incoming XML to a Siebel Message.
- Calls the EAI Data Mapping Engine to transform the external integration object to an internal integration object.
