XML Reference: Siebel eBusiness Application Integration Volume V > XML Integration Objects and the XSD WizardThis chapter discusses the XSD wizard, the supported XSD elements and attributes, and the structure of the XSD XML integration object, such as user properties. |
XML Reference: Siebel eBusiness Application Integration Volume V |
