XML Reference: Siebel eBusiness Application Integration Volume V > XML Integration Objects and the XSD Wizard >
Structure of XSD XML Integration Object
The structure of the XSD XML integration object is same as any other integration object. In this chapter we discuss the properties specific to the XSD XML integration object.
NOTE:  For details on integration objects, see Integration Platform Technologies: Siebel eBusiness Application Integration Volume II.
