Siebel Enterprise Integration Manager Administration Guide > Importing Data > Editing the Configuration File for Import Processing >
Header Section Parameters Used for Imports
Parameters in the header section generally apply to all types of processes. For a description of the necessary contents in the header section, see Header Section Parameters Generic to All EIM Processes.
