Siebel Enterprise Integration Manager Administration Guide > Importing Data > Special Considerations for Imports > Importing Call ListsWhen importing into the S_CALL_LST base table, you need to include the following columns in the ONLY BASE COLUMNS parameter in the EIM configuration file: If these columns are not included in the ONLY BASE COLUMNS parameter, a low-level error will be generated. |
Siebel Enterprise Integration Manager Administration Guide |
