Siebel Enterprise Integration Manager Administration Guide > Running EIM >
Viewing the EIM Log File
In the Task Info Log view, you can view information about the results of an EIM process by drilling down in an EIM server task that has completed. This information is also provided in the EIM log file within the siebel server\log directory. The log consists of three general sections:
  • Startup messages. This section pertains to dictionary loading, parameter loading, and .IFB file parsing.
  • Run-time messages. This section shows the begin and end times for each process.
  • Row-count summary of each process. This section shows the number of rows updated in each table.
If error flags, SQL trace flags, or trace flags were activated for the EIM process, the EIM log file will also contain the results of each flag. For more information on trace flags and error flags, see Using Trace Flags, SQL Trace Flags, and Error Flags.
Further information on the EIM log file is provided as follows:
To view EIM log file information in the Task Info Log
  1. Navigate to Administration - Server Management > Tasks.
  2. In the Tasks list, select the task for the EIM process.
  3. Click the Log tab.
    The log for the selected task is displayed in the Log list.
NOTE:  You can also view this information by opening the EIM log file in the siebel server\log directory.
