Siebel Enterprise Integration Manager Administration Guide > Running EIM > Viewing the EIM Log File >
Setting Event Logging from the Command-Line Interface
You can also set event logging for the EIM component from the Server Manager command line.
To set event logging for the EIM component from the command line
  • Use the following commands:
    change evtloglvl SQLSummary=4 for component eim
    change evtloglvl EIMSQL=4 for component eim
    change evtloglvl TaskConfig=4 for component eim
    change evtloglvl EIMTrace=3 for component eim
Other necessary commands for activating tracing levels are the following:
  • When running the EIM task. Specify the following parameters:
    Srvrmgr> run task for component eim with config=<configfile.ifb>, TraceFLags=1, ErrorFlags=1, SQLFlags=8
  • To view existing event log levels for the EIM component. Use the following command:
    Srvrmg> list evtloglvl for component eim
